first time doing my own brakes???
Can someone give me detailed instructions on how to change brake pads. I'm just getting into the whole car seen, I haven't had a car since I was 16. I know its probably not that hard to do. but I've never done it and don't wanna **** anything up
Thanks.
Thanks.
Tire off
Remove caliper
remove pads
Check slide pins (grease)
Remove fluid lid under hood
press piston into caliper (c-clamp or hammer handle)
Grease pad clips
Install new pads with clips
Slide caliper on rotor
Tighten slide pin bolts
Repeat for each wheel.
Remember to pump brakes before driving off...
Remove caliper
remove pads
Grease pad clips
Definitely find a large enough C clamp or a dedicated tool meant for pushing the piston back in the caliper. You'll save a ton of time and frustration if you have the correct tool.
Try not to let the caliper hang on the brake line, and also inspect the brake line for damage while you are down there.
dont forget to pump the brakes before attempting to drive. Dont want to not have enough pressure built to stop and run into something. seen it happen to a kid in auto shop lol. heres a video i pulled up from advanced auto
http://www.autozone.com/autozone/vid...video=56W4KXY9
Do one at a time and don't pump the break up until after all 4 are done. Watched my neighbor do his one time and shot the piston out of the caliper... Also be sure not to pinch the rubber boot that is being compressed with the caliper. You'll be replacing a caliper if you! Shouldn't take you more than 30-45 mins to do all 4. Good luck!
Can you elaborate on this a little? Ive done plenty of brake jobs on my mustangs but this is my first F body. Ive never done anything like that on a mustang, I already changed the pads once on the camaro but its gonna be time for new rotors soon so id like to know. thanks
Save the manuals!
Your Mustangs or other models of car that don't have this parking brake design can probably be adjusted with the rotors and brakes on the car, so the timing of that adjustment wouldn't be as critical.
Maybe I should have said "check the adjustment?" Its possible that a new rotor is close enough to the old one that physical adjustment is not required after a change. It should still be checked before the brakes go back on over the rotor. (Having to take them all apart to do an adjustment after the fact is a total PITA.)
bleed the brakes when the pads are replaced.if your rotors aren't grooved you can fluff them up with a drill and a 3M wheel.when you put the wheels on try spinning the tires to make sure you don't have a sticky caliper after bleeding the brakes.
