Help! Some huge bolt fell off, need help to identify
That bolt is torque to yield and requires a certain torque sequence. not replacing it with a new bolt risks the balancer spinning freely and damaging the crank shaft. I had one come loose years ago when a mechanic doing a motor swap for me failed to use a new bolt and the balancer rounded off a chunk of the crankshaft as well as the messing up the front cover seal. I ended needing a new crank. Is it worth the risk not replacing it? Also you could probably find one on ebay.de if your creative in your search and have it in less than a week.
Big-*** breaker bar is not a problem, but how would I lock the crank? I tried locking one of torque converter's pad against ground, but at ~120lbs*ft whole nose starts to rise
edit: yes this was the balancer bolt ( how lucky I was to loose it at 40mph not 120
No problem, I'm ordering the bolt tomorrow and it will be here in about 11 days. As far as I remember service manual says 37lbs and then 140 degrees more, BUT before this OLD bolt must be installed with 240lbs*ft which is huge. Damn that's twice the torque typical Honda makes :O
I don't know, this whole "240lbs" thing looks stupid and crazy to me.
