Help! Some huge bolt fell off, need help to identify
Sounds silly I know. But this night after some testing on the road I heard sound like smth. small fell off, stopped and saw huge bolt on the road. I don't remember seeing such bolt anywhere. K-member bolts are similar size but it's not one of them... It was 5am so I was dead tired and couldn't return to base to check everything...
Help!
Help!
How long is it? Hard to tell in the pic, but that almost looks like a brake caliper bolt or something else in that general area. Could explain why it was warm if it came from near the wheels
have you changed balancers or pulled the old one for motor work in the past?
you should always use a new bolt on install or restall.
it might not of been torqued to speck on install or the pulley was never on 100%.or some one reused an old bolt.....thats a couple of reasons they fall out.
good luck!
LS1Tech Premium Sponsor
Definitely a balancer bolt. I would put a new balancer bolt in with some red Loctite and tighten it down with an impact and you should be good to go. Your local GM dealership should have that bolt in stock so you shouldn't have much down time at all.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
