new plugs, rough idle
If after, then it stands to reason that something is wrong with the new parts you have installed. You said you've checked the wires for tightness, but it's possible that a wire might be bad. Or that plug gaps might be off. Or that a spark plug may have a hairline crack that could have happened during install (especially if you dropped any while installing them).
What brand of wires did you use?
Recheck your work on the cold cylinder.
