Transmission Crossmember won't line up
Long story short, my 2000 Trans Am got wrecked and I'm swapping everything over to a 1994 Firebird body. Last night, I was finally getting the motor into the body and as I'm bolting everything up, I noticed this:
The passenger side lines up and bolts up fine, but the driver side is easily 6 inches off. Were there differences in the bodies for the early 4th gens? Everything else on the car is identical to my 2000, and this is the first difference I have found. How would you all go about fixing this? Fabricate an adapter?
LS1Tech Premium Sponsor
You are correct, the Lt1 cars and LS1 cars have a little different floorboards so you need make sure you use a T56 crossmember from an LT1 car (93-97) and everything should line up.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
