Sponsored by: CARiD
how hard????? a/c compressor
Old Oct 26, 2012 | 06:39 PM
shaun's Avatar
Red face how hard????? a/c compressor
hey guys my compressor took a crap so i have all new parts and i was wondering how hard is it to swap it out?
Old Oct 26, 2012 | 06:52 PM
sjsingle1's Avatar
easy as pie
Old Oct 26, 2012 | 10:09 PM
3Camaros's Avatar
If you can change your spark plugs you can replace the compressor. The last one I did I bought off Ebay as a rebuilt kit (dryer, tube, oil included). You can get the vacuum pump and gauge set as a loaner tool from Autozone.
Get the front of the car up on jackstands as most of the access is from the bottom. Take the belt off, then upbolt the compressor before you try to get the hoses. If I remember right there are four bolts and the top two are kind of hard to get to. After you get the compressor loose you can move it around to get the hoses and wire connector. Of course you want to bleed out any freon left before you disconnect the hoses. All the instructions I have read say to replace the accumulator/dryer and tube at the same time. You put the oil in the new compressor and then rotate it by hand after connecting the hoses. Before any freon goes in you pull a vacuum (with vacuum pump), the longer the better (say at least 10 minutes). You want the car running and AC on when you put the freon in. I think I used three cans.
That's about all I remember. All in all not that hard, I would probably do it in 2-3 hours.
Old Oct 27, 2012 | 12:58 AM
99'CajunFirehawk157's Avatar
Four bolts hold mine to my block; 2 top, 2 bottom.1 word of caution: do not over torque the bolts when remounting the new compressor or you can cause rear seal failure and all your hard work and $ goes out the window. Check your torque values on the mounting bolts w/a torque wrench.
Old Mar 13, 2013 | 08:19 PM
LS1 pwrd NOVA's Avatar
Is it really this easy?
Old Mar 14, 2013 | 05:43 AM
mjs1012's Avatar
Yes. Just run all the hoses to where they're supposed to go and that's it
Old Mar 14, 2013 | 06:20 AM
senicalj4579's Avatar
One of the easiest jobs.....
Old Mar 16, 2013 | 12:23 PM
So should I take this on myself and save $350 in labor? I work on my own stuff any how. It sounds simple from what you guys are saying.
Old Mar 17, 2013 | 01:29 PM
2000PewterT/A's Avatar
I would its really not hard, if you don't know how to recharge the ac system you can have someone else do it but definitely change the compressor yourself.
Old Mar 17, 2013 | 05:13 PM
need4fun2469's Avatar
I changed my comp, dryer and OT then took it to a garage to have it charged. swapping out the comp and components took me 1/2 hour.
