Oil leak now?!
Wtf is going on, it just randomly starts leaking oil like a siv?
The car has NEVER leaked even the slightest drip of anything in the garage and now since the last oil change it drips like a 2" spot every time its driven.
So wtf, ive cleaned under it twice now and checked everything i can see and theres not oil coming from anything. It just hangs from 1 rib on the bellhousing, and a bellhousing bolt on the passenger side of the car. Ive taken the inspection cover off the bellhousing and felt around in there thinking it might be the rear main seal, but its completely dry, thought maybe the oil filter wasnt tight but no oil there. Looked up the sides of the block, no oil. Its honestly like its coming from nowhere?
Is there any possible way that i overfilled it somehow and its slowly leaking from somewhere till it gets back to where it wants? lol im just at a loss here..
F-Bodies take 5.5 quarts.
I would not necessarily agree with the 10-40 not posing an issue and I am not much for coincidence. I don't like the idea of just some oil viscosity not approved by GM to be added to the LS1. The 10-30 is already thick enough when it calls for a 5-30 originally...How much more thickness do you want??? Those gaskets cant take the abuse. Just my $0.02.
For this guy, I hope its that sensor, but c'mon now. If you are going to do oil changes, then do it rite?
I highly doubt using a little thicker oil would just all of the sudden "ruin all the gaskets in the engine" but what do i know because i used 10w40 oil once. :rollseyes:
Have you looked into it yet? I am just curious as to whats going on with the car.
Obviously i have looked into it and cant seem to figure out where its coming from, hence asking the question on here. If you have nothing to add or help me come to a conclusion on whats going on, refrain from posting.
Thanks.
they DO sell this dye that you can add too your oil, which im sure your aware of, which glows under a black light (you can rent black lights at some shops if you ask). add the dye, run the car for a few days, and shine that thing under the car to find the leak. do NOT clean all the old oil off, since when you add the dye you will immediatley be able to see exactly where it is, in this case, the more oil it leaks the easier it will be too see the glowing dye in the oil. the dye itself doesnt hurt anything. this is how we find oil leaks in aircraft engines.
Adding engine dye will definitely help you identify some leaks but if it is the rear cover leaking it will not do anything but irritate you since it shows you nothing but a glowing blob of **** between the engine and trans.
I like many many other people on here have had a leak from the rear cover and what happens is the oil gets blown around by the flywheel so you will see it on the starter housing, rear of the oil pan, between the trans housing and if you pop off the little inspection covers it usually looks dry but dont be fooled.
Some poeple have luck with our engines and experiece zero leaks over 100k but thats very rare. If you have time drop the transmission and start replacing some gaskets and seals. If you are really bored drop the oil pan and replace that dreaded gasket as well.
Hard to diag leaks online for obvious reasons but I believe you are experiencing the rear cover leaking but good luck man.
Picture of the rear cover:
