coolant reservoir hose
Old 01-01-2013 | 06:52 PM
guy7bmwm83's Avatar
Default coolant reservoir hose
I just discovered the battery tray is broken at the front. I found gm part number 10402687 or the dorman equivalent, but where can I find the hose that attaches to the tank? I checked rockauto, gmpartsdirect, and nothing. I searched old threads, but did not find anyone mention replacing this hose. What have others done? Can I cut off that metal piece at the end of the hose at the tank and just attach a new hose with a clamp, and reuse the old pipe/grommet from the old tank?
Old 01-01-2013 | 08:42 PM
CottSculp's Avatar
thats almost exactly what I did. worked like a charm. i got rid of my stock coolant reservoir though because it cracked at the bottom. Broke it off from the battery tray and bought a jegs brand 1 qt recovery tank. i used their provided hose and cut the metal pipe leaving about 1 inch exposed. i slid the new hose onto it, hose clamped it, slid it under the battery to the new tank, and plugged the other end into the radiator. works perfectly.
Old 01-02-2013 | 08:02 AM
wssix99's Avatar
Save the manuals!
You just pull the old hose out and put it in the new tank. Its not physically attached or integral to the tank.
Old 01-02-2013 | 02:27 PM
sjsingle1's Avatar
if the hose is not bad...........reuse it........its a PITA to get out but it does come out.........use wd40 at the grommet in the reservoir and pull
Old 01-04-2013 | 09:24 PM
guy7bmwm83's Avatar
I may have found part numbers for this hose.
Goodyear 64269
HVAC Heater Hose; Throttle Body Heater Outlet; Cut to fit; Radiator To Reservoir
Gates 18254
Molded Heater Hose; Throttle Body Heater Outlet; Cut to fit; Radiator To Reservoir
I ordered the Goodyear one from Summit Racing.
Quick Reply: coolant reservoir hose
