Coolant shooting out!!!
....i have a fan switch so i just turned it on and made it same home...i never had prob with the fan switch(homemade) so can it be the stat or what...PLEASE HELP. What does the exhaust look like? Does your oil appear milky? Just check for signs of coolant in your oil, or burning off coolant... they're tell tale signs of a dropped head gasket...
I experienced coolant "exploding" out the reservoir when the car got hot. The motor was brand new warranty replacement GM.
Eventually, we found that the guys who installed my motor hooked up the coolant lines incorrectly at the radiator. The tube coming from the heads is *supposed* to go below the tube going to the overflow container. They had it the opposite - the tube going to the overflow was hooked to the nipple below, and the tube going to the back of the heads was hooked to the upper nipple.
Hooked it up right, no more problems.
Since you had radiator work done recently, hmmm...
