Sponsored by: CARiD
grind/rubbing noise when turning
Old Mar 23, 2013 | 02:38 PM
ronald.fields's Avatar
Question grind/rubbing noise when turning
ok, so 2000 z28, almost 170k on body, its been making a grinding/ rubbing sound when i turn so i replaced the wheel hubs. seemed like the noise went away for a little bit but its back. also just had the rear rebuilt with 3:73 gears with new bearings, races, seels so i dont think its anything in the rear (it was making this noise before the rear was rebuilt). it sounds like its coming from the passenger from wheel well. any idea guys? its driving me crazy
Old Mar 23, 2013 | 04:29 PM
Zlow28's Avatar
Are you lowered or running oversized tires?
Old Mar 23, 2013 | 04:52 PM
stock ride hight, just have corvette z06 wheels. checked for tire rub and nothing...
Old Mar 23, 2013 | 06:14 PM
hershey1's Avatar
I had the same issue, it ended up being a pitted axle. Replaced the axle and axle bearing and was good to go.
Old Mar 23, 2013 | 06:19 PM
axel are fine and new axel bearings when we put the gears in
Old Mar 23, 2013 | 06:29 PM
hershey1's Avatar
Old Mar 23, 2013 | 06:30 PM
hershey1's Avatar
Sorry for the double post. Let us know what you find.
Old Mar 23, 2013 | 06:37 PM
im stumped, it sounds like its coming from the passenger front tire. i dont hear it when the car is sitting at idle and i turn the wheels, but when i make a turn doing around 30 miles an hour
Old Mar 25, 2013 | 08:04 PM
rpcase's Avatar
My car does this same exact thing. Has 17k miles on it. Sounds like a tire rubbing plastic. It does it even when the wheel isnt turned too far so i doubt it is actually rubbing. Sound comes crom same area as you. Drives me nuts!!!!
Old Mar 30, 2013 | 06:33 PM
i know, i keep looking looking but nothing, pisses me off!!!!!
Old Dec 18, 2013 | 05:20 PM
Mark01ta's Avatar
My trans am is making the same noise in from the wheel wells but only while giving it gas while turning, like making a right or left at a stop sign. Would really like to figure this out.
Old May 10, 2021 | 11:16 PM
Mikeypooh1's Avatar
Did any of y’all ever figure it out? I just installed my new QP 9” and is doing the same thing...only on right turns
Old Jun 5, 2021 | 03:37 PM
Matt45's Avatar
My camaro just started doing this it’s annoying me! You find out what it is?
Old Jun 5, 2021 | 08:43 PM
Mikeypooh1's Avatar
In my case, it turned out to be that the rear end wasn't centered perfectly, plus the rear sway bar link had broken on a test launch.
I adjusted the panhard bar and replaced link...problem solved! Now I have awesome launches 1.6-1.7 60’
By Brett Foote | 2026-06-04 05:00:17
