Sponsored by: CARiD
would this throw a code?
Old Apr 15, 2013 | 07:31 PM
kingof951's Avatar
Default would this throw a code?
keep getting p0430 bank 2 catalyst effeciency below threshold. would this cause it u think? anyone?
Old Apr 15, 2013 | 07:32 PM
kingof951's Avatar
dont see or hear any exhaust leaks. just the big *** dent btw
Old Apr 15, 2013 | 07:37 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
That dimple is normal. They all came that way from the factory.
P0430 is a common code. It simply means that cat efficiency is below a preset threshold (thus a reduced oxygen storage capacity of the cat, and an increase in tail pipe emissions). In some rare cases, replacing the O2 sensor will solve this. Mostly, the issue is that coatings have worn off the cat substrate and emissions levels have increased.
You live in CA so you'll have to deal with this at some point to pass emissions.
Old Apr 16, 2013 | 03:02 AM
kingof951's Avatar
ok. yea i figured it was a bad cat. been looking for a replacement on here but no luck. thanks
Old Apr 16, 2013 | 08:50 AM
wssix99's Avatar
Save the manuals!
I'd also shake the pipe a bit and see if you hear any rattling. You could also have a broken substrate in the CAT.
As RPM WS6 pointed out, the O2 sensor is much more likely to be the culprit at this age - so that's the place to start if there are no obvious signs of breakage in the CAT.
Old Apr 16, 2013 | 11:22 AM
RPM WS6's Avatar
Here is another thread from yesterday about this:
https://ls1tech.com/forums/general-m...smog-test.html
In this case, the cats were still working as per the sniffer test results, even though this code was present. If yours still passes the CA sniffer too, and it's only the code that is causing you to fail an OBD scan test, then you can always disable P0420/P0430 via custom tuning.
Old Apr 16, 2013 | 12:57 PM
kingof951's Avatar
Ill switch the bank one and bank two cats and see if I get a 420 instead of 430
Old Apr 16, 2013 | 01:23 PM
RPM WS6's Avatar
Be advised that doing so would require custom fabrication since the factory cats, as designed for the stock exhaust, are not interchangeable between banks.
You could, however, swap O2 sensors from bank to bank and see what happens. In the thead I linked above, I believe that new O2 sensors still didn't get rid of the code, yet the cats managed to pass the exhaust sniffer just fine. That was why I recommended code deletion to the poster in the other thread.
Old Apr 16, 2013 | 01:34 PM
kingof951's Avatar
That's what I meant o2s lol. Sorry I just woke up. And code deletion wouldn't show up on the obd smog test?
Old Apr 16, 2013 | 01:35 PM
kingof951's Avatar
I live in CA smog test rape capitol of the world.
Old Apr 16, 2013 | 01:47 PM
wssix99's Avatar
Save the manuals!
Don't forget anti-size compound on the sensors when you switch them. (Under warranty repairs) A dealer took one of mine out and didn't apply the compound.
That was very very very bad...
Old Apr 16, 2013 | 04:02 PM
kingof951's Avatar
Yea I've had that happen to me too. Any thoughts on the code delete and CA smog?
Old Apr 16, 2013 | 04:23 PM
wssix99's Avatar
Save the manuals!
Clearing the code is easy. Most scanners will do that for you. The catch is that you have to drive the car for a while afterwards in order for the car to build up enough history to pass the test.
Old Apr 16, 2013 | 08:28 PM
kingof951's Avatar
oh i have a scanner that i keep deleting the code with but it always comes back. just wondering if a permanent tune delete or o2 sim would still pass smog
Old Apr 16, 2013 | 09:49 PM
RPM WS6's Avatar
It does here in IL, I know that first hand.
I can only assume that the scan test portion is the same in CA, but I can't know for sure.
Old Apr 16, 2013 | 10:34 PM
kingof951's Avatar
Ok thanks for the answers
