abs/brake/trac off light?
2005 gto
How would I be able to determine if its bad
275/35/18 which were on when it was originally tuned
By my calculations, you went from a 25.6" diameter tire to a 26.3" tire. If you didn't tune to compensate for this, it could be your problem.
If you are traveling 35 mph at the wheels, the PCM will think you are only going 34 mph. But at 65 mph, the PCM will expect that you are going 63, which may be enough for the ABS system to think something is wrong with the speed sensors.
& C0896 Out Of Range Voltage At The EBTCM Probable Causes; Charging system fault, Open or short circuit condition, Poor electrical connection, Failed relay condition, Ignition switch fault.
I'm the original owner and I'm at 137,000 miles. I have had the above codes come on and off for a couple of months, and have since replaced the front wheel hub assembly's that included wheel sensors, replaced alternator, and "just" cleaned the rear sensors for the first time, one had a strand of wire stuck to it (wire not in photo below).
Cleared codes, I'll have to drive it for about a week and see if codes come back, hopefully it was just the dirty rear sensors.
ABS Trouble Code Search
http://www.wellsve.com/custom_search...45&Submit.y=18
2000 F-Body DTC's
http://www.gearchatter.com/viewforum36.php
Manufacturer: AC Delco
UPC: 707773298091
P/N 12457657 - Electronic Brake Control Module Kit
$620.75
