Seafoam??
There is a sticker on the intake of my 98 f-150 that specifically says not to use any additives or cleaners through the intake system. Why it says that I don't know, but I leave that part alone. Likewise I'm pretty skeptical about putting it through my lubrication system for fear of either lowering the oil pressure too much or screwing up one of the seals, but I agree with the one poster above....if you just idle it and don't put it under a load it's probably fine. Don't get me wrong, it's pretty gummy in my intake...you can literally scrape off the varnish with a knife, but I've had it for 15 years with 180,000 miles on it and the performance and fuel mileage has pretty much stayed the same....so I'm not going to mess with it. My Camaro has even more varnish and I guess if I was worried about emissions like the other poster abover, or every little hundreds of a second in the quarter mile...then I'd try to clean it.....but otherwise I'd leave it alone. Just my opinion, but I don't have any facts to back it up.
This way you won't risk fouling a good 02 sensor.
It's very very rare....but I guess it has happened.
You should get better throttle response and smoother acceleration.
For the best fuel system cleaner use bg 44k. It runs through your gas tank and I would never trust anything that says you can add it to your gas and or oil. You can find bg products at @bgfindashop.com
Yea, no reason to mess with it it's doing fine. If you ever do decide to, get the engine up to operating temp THEN remove the 02 sensors.....then idle it and spray a can into the front of the intake or let it get sucked into the TB if possible. Then shut it off and let it sit for 2 hours. Them start it and let it idle for 15 min, then put the 02 sensors back in and go drive it.
That BG44K is very powerful stuff and the price indicates that, usually around $18 - $20. My GM dealership stocks it and my Porsche mechanic used it on a 911 I used to own. Very effective product for the fuel system. One word of caution from the service advisor, if you accidentally spill on the paint, clean immediately!
Save the manuals!
We need a better thread that is in line with the manufacturer's instructions, is technically focused, and presents the alternatives. All of these products use the exact same (or similar) mixture of chemicals. However, there are some that have different apparatus for cleaning different areas (Chrysler's and GM's products/tools come to mind along with MotorVac.) and those options should be covered as well.
Great point. Where is the beating-a-dead-horse emoticon???
Years ago I posted a how-to, with pictures, to use MCCC or other Foam products to properly clean the top end. Don't know where it went.
Also.....even though most cleaning products for this purpose share most of the same ingredients, if its not a FOAM it cannot do a complete or very good job in cleaning the top end, especially the intake. Also....people need to know that introduction of any product, even a Foam, will do almost nothing unless it is introduced in the FRONT of the intake somewhere. Introduction at the rear of the intake will only impact the rear two cylinders, and only clean them a little bit.
