Fluctuating temp Gauge, tough starting, bogging/buckling and running rich
Hey guys I have a 98 ws6 it's running really funny. I did a real good tune up on it this winter. The thread title explains my issues. I believe it could be a cam or crank sensor giving me this problem? The car only bogs and buckles, losing fuel when the temp Gauge goes below 0, as if it isn't even getting a reading. It also idles somewhat rough but it's been idling somewhat funny for a few months now. I will likely change the temp sensor just in case it's that but any suggestions?? Thanks in advance
Believe it or not......98's will run like that with a failing Coolant Temp Sensor. My engine will hardly stay on.....backfires, spits, sputters and will NOT drive. The second you try to add some throttle to pull away it will stall. Pop in a new Temp Sensor.....ran perfect.
Change it out......see what happens.
It could be something else like a shorting out wire or the PCM is going out.....but it sure sounds like a coolant temp sensor on its way out. Easy cheap fix.
And if it doesn't fix the problem.....you can clean it and return it. Just tell them you never installed it and it was the wrong one because someone put aftermarket heads on your car so you had to go buy a special one. They'll have no clue and give you a refund.
if PCM is getting bad info on engines true temp
it will run different and erratically.
Ok guys well I changed the temp sensor a few times (warrantied it out) as well as the pigtail going to it... today I started it, drove it, got gas, started it back up and boom it started losing reading on the temperature and running very badly. Open loop. I am full on coolant.
My thought is that it could possibly be the thermostat getting stuck open or closed? In which case maybe I should try the thermostat next? Everytime I get a code it is a temp sensor code. I have checked for pinched wires and everything. I can't find anything else that would be causing this issue.
Please give me some input. I will likely change the thermostat tomorrow just to see what happens. It seems that this only happens on very hot days, and never the first startup. It always happens after I drive it somewhere, turn it off and start it up like 3 minutes later.
Or is there any chance it could be my Cam or Crank sensor starting to go?? I don't know lol
