Sponsored by: CARiD
Bunch of error codes after rain storm.
Old Jun 16, 2013 | 03:55 PM
DjinnWS6's Avatar
Default Bunch of error codes after rain storm.
I got stuck in this big storm that hit us a few days ago, and I hit a decent size puddle and pretty soon after my service engine light is on and the car is driving like crap. A lot of stuttering / chugging / lunging not sure what you'd call it but it's not good. I was assuming I fried an 02 sensor and I finally got an it hooked up to see the codes and these are the codes I'm getting.
The car is an 02 TA Firehawk. all stock aside from headers / exhaust.
c0890
c0550
These 2 are ABS Codes from what I could find.
P0151 - H02S21 circuit condition (heated oxygen sensor bank 2 sensor 1)
P0171 - Fuel trim bank one condition
P0174 - Fuel trim bank two condition
P1380 - Misfire detected, rough road data unusable. The ECM has detected a misfire but was unable to detect a rough road condition due to a ABS system malfunction
P0300 - Cylinder misfire detected - random cylinders
Aside from the ABS thing which isn't related to the engine misfire, could 1 bad O2 sensor cause all of this? I'm going to head to autozone now to get an oxygen sensor to replace the one noted in the error code.
Also does anyone have any ideas on the ABS Codes ? I couldn't find anything from a quick google search..
Thanks
Old Jun 17, 2013 | 02:19 PM
1 FMF's Avatar
you got your abs sensors in the wheel hubs wet. not uncommon. i put new front wheel hubs on my truck last summer which have integrated abs sensors, drove south with the truck and hit a monsoon in NC on the highway, set off both front ABS sensor DTC's. got to where i was going, cleared the codes, never came back and never had a problem since. so i would clear your codes and see what comes back in dry conditions before you do anything. maybe unplug each o2 sensor and check the plugs for bad/burnt/corroded pins then reseat them, and you should monitor them with a scanner to see if they are switching fast enough. one o2 sensor would not cause p0171 and p0174. but given a wet condition it may have been water into the maf and intake causing everything, especially if you have a modified or aftermarket intake.
Old Jun 20, 2013 | 06:50 PM
DjinnWS6's Avatar
It's a blackwing airlid assembly that came with the car... I did notice tho that there is a nickel sized hole in the drivers side of the air lid with some kind of rubber grommet inside of it but the hole leads right into the airbox. Is that supposed to be there or is there a plug missing?
Old Jun 21, 2013 | 05:43 AM
_JB_'s Avatar
Post a pic. It could be two things: IAT or a tube thats supposed to connect to the AIR system.
Old Jun 21, 2013 | 01:24 PM
DjinnWS6's Avatar
http://s420.photobucket.com/user/dou.../lid1.jpg.html
This isn't of my airlid. This is just a pic i found on the internet.
The black plastic part on the right side of the pic with the 90 degree elbow in it is what mine is missing. It has a hole there but no hose or anything else going into it. There is a sensor plugged into it towards the back of the airlid tho.
I'll post pics of mine when i get a chanc.e
Old Jun 21, 2013 | 01:37 PM
DjinnWS6's Avatar
here is another pic i found,
the yellow circle is what my car HAS on it,
the red square is the part mine is missing. What is this for, is it functional / ok to run without it. ?
Old Jun 21, 2013 | 05:26 PM
_JB_'s Avatar
Yellow is the IAT and red is for the AIR system. I'd plug the hole as its bypassing your filter.
Old Jun 21, 2013 | 05:50 PM
DjinnWS6's Avatar
I'll try that and see if it helps how its running. I dont have a scanner to delete the codes so I'll be bringing it up to auto zone tomorrow to do that real quick and see what comes back.
Old Jun 21, 2013 | 09:07 PM
superlazy's Avatar
The parts store may not clear your codes.they told me it was illegal for them to do so. Disco the batt.for the night that should do it.
Old Jun 21, 2013 | 11:22 PM
garygnu's Avatar
pull apart all electric conections in the engine compartment and dry them with a hair dryer.the O2 sensor wires,the IAT,and IAC wires also.
Old Jun 22, 2013 | 01:08 AM
_JB_'s Avatar
The car won't run any different with the hole plugged, but it should be plugged.
