A/C leaking freon somewhere
Can someone chime in on any repeat offender areas on these car's A/C system???
Thanks
Thanks for the input
) The only hit we can find is behind the compressor and it is not a steady hit. It reads then goes back to beeping..... I guess it just might be the seals on the back side. Trending Topics
OP, another place to check is the compressor case seal. The case splits in two about 1/2 way along its length, and there's an oring at that joint.
