Traction control popping
Thanks fellas. First time to own a car with traction control
If its the sound that bothers you, I'd have someone watch your brake calipers when this happens and see if there is any movement there. (Maybe you have a loose caliper?)
The other thing the TCS does is to activate the ABS braking system to prevent a spin out under slippery road conditions. The popping you are experiencing is the brakes being activated to prevent wheel spin.
You can't do a power launch with the TCS on. This is not a sophisticated traction control like you might find on a newer Corvette, it only tries to prevent wheel spin.
There are modules available that plug in behind the TCS switch the will change the default setting to always off instead of the always on stock setting. Or you can just hit the button to turn it off each time you start the car.
The TCS in these cars is next to useless, it exists only to keep an inexperienced driver from spinning out and losing control under conditions of too much power for road conditions. It will actively prevent you from making a clean power launch.
