LS6 valley cover install on f-body, how hard is it?
thanks for all the input guys. I'm listening to all of you. Can I put the o-rings on dry or do I need to use some sort of adhesive, like the copper spray that is used frequently with head gasket jobs? I was reading something about silicone based lubricant? I'm not too clear on this.
It's not mine! woo hoo!
No, you just pull (or pry, in my case) the old ones out and slide the new ones in.
Also, like was mentioned, just pick up a Fel-Pro set from your local parts store if you need them (MS 92438 -- $20 pretty much everywhere). You might not, but I just wanted to mention them so you wouldn't be surprised. If you want to stick with OE, the ACDelco number is 12533587 and they're $57 from Amazon.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Thanks again for your help, and also everyone else
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
If you still have a PCV valve, then it's likely it was never done. Now, I say that with one caveat: the initial LS6 valley covers retained the external PCV system; it wasn't until 2004 that it was eliminated. With that said, I don't believe that the valley cover conversion really became a "must have" modification until more recently (in comparison to the life of the Gen III/IV engines), so most people that have done the modification have done it with the 2004 cover rather than the 01-03 cover.
