How to clean inside of intake?
Have you looked for the Plastic ID stamp on the part? (It might be under one of the foam pads on the bottom of the intake. Once you know the material, choosing a chemical becomes really easy.
ABS does not hold up to gasoline, kerosene, etc. very well. Same goes for Alcohols. (Although, I like to use dilute alcohol for cleaning really dirty trim pieces as it takes off a little bit of the surface and leave it looking like new.)
If the funk on your intake is like a water scale, etc. I'd try using CLR first.
http://www.newmantools.com/pipestopp...istance_nt.pdf
http://www.matweb.com/search/DataShe...6e21eed&ckck=1
https://www.google.com.mx/search?q=p...w=1280&bih=533
http://www.professionalplastics.com/ACRONYMS
I did do the wire mod, remove egr and smog, cleaned my inner fenders. Intake and paint the radiator support are next.
