Fuel gauge past full
Fuel gauge sits past full when I start the car, eventually after driving it goes back to normal. Is there something that im going to have to replace soon? sending unit? car is a 99 Camaro ss
Mine also does this and I believe it is the actual gauge itself IN the instrument cluster, and NOT the sending unit in the tank, since I just replaced the WHOLE/COMPLETE in tank fuel module assembly, and it still does this.
Mine will go to a normal reading if you tap the actual gauge in the corner of the cluster, does yours do this as well??
Next time you start it up and it is all the way to the right, way past the full mark, try tapping fairly hard on the cluster bezel plastic cover right over the fuel gauge, and see if it springs back to the correct reading.
If it does this, then it is the actual gauge itself and not anything back in the tank.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
If it does this, then it is the actual gauge itself and not anything back in the tank.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
That I do not know, but I suspect it would be a whole new cluster given the way these cars are, and I personally would not bother with it at all (unless someone could sell me one with the airbag led already surgically removed from it, since I have an aftermarket wheel with NO airbag).
that actually seems like a good idea. that wouldn't damage the gear or whatever you want to call it that the needle rotates around? idk if it would keep trying to go past full but the stopper would be blocking it so it would have sort of a grinding effect
I am wondering if the cluster gauges use a 'clock spring' type device in them, since when mine goes all the way to the right at start up, it sort of 'springs' back into the correct position when I tap it??
