Right Front Turn Signal
Thanks
- Turning on the headlights with the car off
- If the hazards work
the cause of the problem may be revealed.
I am also having a similar problem. My front right turn signal will not illuminate and no green arrow on at the cluster. It does illuminate with the hazards on and the green arrow blinks like normal.
I replaced the signal flasher and bulbs with no results.
Have you found a solution yet to your problem?
If the 552 is working on the left, its just luck. The two sides of the car have slightly different resistance which can impact how the electromechanical flasher works on each side.
I recall that the blinker flasher is a 323 - or you can get an electronic flasher instead.
When the flasher is bad, the light will usually be on but solid, but it could be off.
ALL of your wiring, bulb filaments, etc. are identical between the DRL module and the bulbs, so you shouldn't have to worry about much there.
You'll want to focus on the turn signal assembly (in the steering column) and at the DRL inputs.
At this point, I'd say the most likely issue is a problem in the turn signal assembly. You should be able to confirm all of this at the connector at the base of the steering column. All you need is a wiring schematic and it should be pretty easy to see if the right turn input is getting from the switch and down the column to the DRL module.
Any particular switch manufacturer I should use?
Advance Auto has a Wells brand, is this a good fit?
These threads should help:
https://ls1tech.com/forums/general-m...oval-pics.html
https://ls1tech.com/forums/general-m...mn-repair.html
