Sponsored by: CARiD
Buzzing with the heater on
Old Mar 20, 2014 | 08:17 AM
ShawnD's Avatar
Default Buzzing with the heater on
When I turn the heater on there is a crazy buzzing sound that gets louder with more fan speed. Coming from the passenger side footwell.
Could the blower box (not sure if that is the correct label for it) be loose or possibly have debris in it? Anyone else experienced this?
TIA!
Shawn
Old Mar 20, 2014 | 08:19 AM
Tolley's94z28's Avatar
TIA!
Shawn
That, or it could be trying to die.
Old Mar 20, 2014 | 08:26 AM
ShawnD's Avatar
Come on man...don't tell me that. ha!
Old Mar 20, 2014 | 08:47 AM
Zmg00camaross's Avatar
Possible mouse nest to blower motor going bad. Fan blades break can make it have a vibration humming noise. Remove and inspect.
Old Mar 20, 2014 | 08:54 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I've had to clean mine out before for this same reason. Turned out to be leaves/debris, no big deal at all. The motor is easy to remove on these.
Old Mar 20, 2014 | 10:01 AM
Worst case scenario broski! It probably isn't that, though!
Old Mar 21, 2014 | 03:25 PM
ShawnD's Avatar
Could be leaves...**** TON of them in the cracks/crevices of this car I picked up.
I will search for the DIY on removing the motor. Thanks dudes!
Old Mar 21, 2014 | 04:21 PM
libertyforall1776's Avatar
I have the same issue on my '02 Camaro RS -- I suspect leaves -- still need to pull it out and inspect it.
Old Mar 21, 2014 | 10:32 PM
ShawnD's Avatar
Turned on the a/c today and made the same noise so must be the blower. Better get on the repair before summer kicks in here!
