Sponsored by: CARiD
water pump advise
Old Mar 27, 2014 | 08:00 PM
wicked383lt1's Avatar
Default water pump advise
My water pump is leaking and I just wanna know if should change anything else while i have it off or tips on doing this job to make it easier.
Old Mar 27, 2014 | 09:04 PM
Cajun ELESS-ONE's Avatar
what car. ls1 or lt1?? the ls1 will be easier. the lt1 will be alittle more tricky. iv done both lol
Old Mar 27, 2014 | 09:05 PM
blackbirdls1's Avatar
check your belts, other than that change out the coolant, its a messy job but not too hard might need a set of extra hands, good luck
Old Mar 27, 2014 | 09:36 PM
flush all the crappy dex cool out real well. replace with green premix.
Old Mar 28, 2014 | 01:12 AM
98boxer's Avatar
What pump you get? I had to change my Bosh water pump that went 120k, sound great right? But the inlet where the top hose connects to was corroded, funny as corroded as it was it didn't lead there but i did remove a lot of crude and metal shaving from the hoses cause of the corroded pump. I went with a autozone pump cause low on funds and good or bad am only leaving this pump on for 50k, i recommend get a gm pump, my original didn't corrod as this one did.
Old Mar 28, 2014 | 07:07 AM
wssix99's Avatar
Save the manuals!
This is one of the easiest things to do on the car. It's just messy. (as noted above)
You should change the thermostat and should look at addressing the power steering cooler, if you have one installed on your '98.
Old Mar 28, 2014 | 05:26 PM
Cool...thanks for all the input. I just asked in case there was something I should also do while I had it off. I did it on my lt1 and hated life!
Old Mar 28, 2014 | 05:47 PM
Btw...what's a good pump to go with?
Old Mar 28, 2014 | 07:21 PM
OEM unit. not remaned. new only. do it once and with the right parts
Old Mar 31, 2014 | 07:51 PM
dailydriver's Avatar
Even though they are much more coin, the Evans pump for the LSxes is pretty stout since they upgrade the bearings/seals over what the factory/new GM/Delco part has installed, also a higher flow/higher quality impeller.
But yes, you DO pay for it over even a brand spanking new AC Delco/Delphi/GMB/whatever.
Old Apr 1, 2014 | 10:59 AM
demonspeed's Avatar
It's not mine! woo hoo!
I'll second this. Might as well get everything done while the system is empty. I'd also replace the lower hose as well if it's original.
