Engine shuts down when i take the e-brake off
Old 04-06-2014, 09:55 AM
plum92_camaro's Avatar
Default Engine shuts down when i take the e-brake off
I have an 01 SS (6speed) and when I take the e-brake off the engine shuts down when the e-brake lever hits the switch at the bottom. Why? It has never done this before.
Thank you in advance.
Old 04-06-2014, 09:12 PM
It doesn't give me a lot of hope to see that 93 people have seen this and nobody knows.
Old 04-06-2014, 09:17 PM
jsteele90's Avatar
did you just get the car? previous owner could have installed some type of kill switch. pull the console and check the wiring
Old 04-07-2014, 08:19 PM
the car is new to me as of last fall. It is wrecked but runs and drives. Drove it on the trailer to get it home and moved it around the shop a couple times without any issues. This spring when i went to pull it out of the shop for spring cleaning is when the problem started. Its twice as frustrating when the battery is dead and you have to jump the car. lol. I have removed the console and found the small single wire switch on the emergency brake. the e-brake opens the contact when the lever is let all the way down. Is that stock on these? I can take a pic if it helps. I thought kill switch but haven't seen an on/off for one.
Old 04-11-2014, 06:19 PM
Orange Juice's Avatar
The switch turn the headlights on.
Old 04-16-2014, 04:32 PM
jsteele90's Avatar
have you figured this out?
Old 04-16-2014, 05:53 PM
robert4940's Avatar
make sure its not messing with neutral safety switch or shorting out and back feeding?
Old 04-16-2014, 08:02 PM
sowbelle's Avatar
Sounds to me like you have a battery charging system issue. When the E-brake is let off, the headlights come on and the battery goes way down below required voltage for the engine to continue to run. Charge battery
Old 04-19-2014, 05:42 PM
Thanks, i forgot about the headlight thing. i haven't had a 4th gen in almost 10 years now.
Makes sense but i have one question. Since the car is wrecked, there are no lights on the front, does that make a difference? With no lights there would be no load.
I haven't spent much time on it but i did start it today and turned the headlight switch on and it died right away just like when I take the e-brake off. But like i said there are no lights to generate a load. Could the issue be the two grounds on the upper radiator support? they are currently unhooked while I work on the damaged front end.
Old 04-20-2014, 08:35 PM
sowbelle's Avatar
Are the headlight positive leads grounding? If so, then it is a direct short causing your issue.
Wrecked cars can be an electric night mare but I think you can get it straightened out
Old 04-20-2014, 09:13 PM
they weren't when the headlights were in but i will check that. thank you.
Old 04-21-2014, 11:03 PM
Got it! I checked the head light wiring and found nothing. Hooked the two small grounds up that attach to the upper radiator support and problem solved. Feel kind of dumb now but hey, live and learn right?
Thanks for the help everyone!
Old 04-29-2014, 12:37 PM
Group Hug.
Quick Reply: Engine shuts down when i take the e-brake off
