Strong Arm hatch support
Would the 4897 be too strong for a formula hatch?
the only concern, and I don't know if it could even apply to our cars due to the mount location, is if the stronger lifting force causes the hatch to bow at the attachment points and cause the rear glass to come loose, but I think it would take a lot more strength then that to do it.
I was still pissed about it, until my clear coat failed on my hood
Are cars hatch glass is heavy as ****. Definitely get the lift struts with the extra 10 pounds of force.
Thanks GM for not giving 98's a hatch open dummy light on the gauge cluster!
This was with the stock 98 camaro struts from the factory. When I got new struts not stock Ac Delco's, it lays there just like you explained in your post. So I guess I shouldn't be pissed as this is normal operation. Thank you Daniel for clearing this up for me.
To the OP still get the stronger ones, as long as they lift the hatch to the same height as stock. They should last longer IMO.
Hope this helps anyone that happens to be looking for new struts.
