Sponsored by: CARiD
Abs asr and brake light
Old Aug 10, 2014 | 12:52 AM
MaroMobZ28's Avatar
Default Abs asr and brake light
How come when I get on the freeway my Asr off light, abs inop, and brake light come on ? It's weird this use to happen in my '02 but it only happened a few times. Not as much as my new car
Old Aug 11, 2014 | 10:41 PM
Cpt.Derrek's Avatar
this can be caused by having different sized wheels on the front vs the back.
Old Aug 12, 2014 | 02:40 AM
transwiz's Avatar
Get an abs code reader and see what code it thru. That is true about having different size wheels on front and back will cause it too.
Old Aug 12, 2014 | 11:34 AM
LopeyZ's Avatar
Usually when all of those lights come on at once it's due to a defective ABS block(EBCM)... one located under the hood.
Old Aug 12, 2014 | 11:39 AM
Randolph Ziskey's Avatar
Do you have stock rear??
Old Aug 13, 2014 | 11:59 PM
MaroMobZ28's Avatar
Yes I do
Old Aug 19, 2014 | 09:50 AM
Killer_Z's Avatar
check fuses. thats what caused mine.
Old Aug 20, 2014 | 07:25 AM
2000 WS6 Formula's Avatar
From: From Massapequa, New York / Now in Southern California
Originally Posted by 2000 WS6 Formula
I'm having the same issue, ABS INOP, BRAKE, and TCS OFF, lights on. Codes C0550 = ECU Malfunction Probable Cause; Failed EBCM (TCS)
& C0896 Out Of Range Voltage At The EBTCM Probable Causes; Charging system fault, Open or short circuit condition, Poor electrical connection, Failed relay condition, Ignition switch fault.
I'm the original owner and I'm at 137,000 miles. I have had the above codes come on and off for a couple of months, and have since replaced the front wheel hub assembly's that included wheel sensors, replaced alternator, and "just" cleaned the rear sensors for the first time, one had a strand of wire stuck to it (wire not in photo below).
Cleared codes, I'll have to drive it for about a week and see if codes come back, hopefully it was just the dirty rear sensors.
ABS Trouble Code Search
http://www.wellsve.com/custom_search...45&Submit.y=18
2000 F-Body DTC's
http://www.gearchatter.com/viewforum36.php
Cleaning the sensors didn't help, I'm getting the same issues. Is there any place that sells new or re-manufactured EBCM Electronic Brake Control Modules for a reasonable price?
Manufacturer: AC Delco
UPC: 707773298091
P/N 12457657 - Electronic Brake Control Module Kit
$620.75
Top three aluminum wires were broken (2nd & 3rd photo), lights would come on after engine bay got hot. I used silver epoxy, and added silicone sealant on those three wires. No problems since, You need a steady hand and a microscope to do this.
