Gen 4 Camaro - Driver Window falling toward car.
Anyone know where I can find a diagram with partlist of everything attached to the window inside the door?
I got my door panel off and I can't seem to figure out what should be providing resistance (that isn't) to prevent my window from falling toward the car. The window also slides sideways because without that preventative force, it's bolt pops out and around the lips of the vertical metal track.
Any/all help is greatly appreciated.
Do you have the two brush assemblies installed on the door?
See the first post, labeled "A" and "B". My window used to lean in towards the car a little bit, and when I removed the panel to fix a crack, I found out that I was missing one of the brush assemblies. Was like $12 from the dealer.
https://ls1tech.com/forums/appearanc...-write-up.html
