Sponsored by: CARiD
Engine using oil???? NEED HELP!!
Old Nov 6, 2014 | 03:19 PM
Fier23's Avatar
Default Engine using oil???? NEED HELP!!
So I recently changed my oil and filter 1500miles ago. All Royal Purple. My car doesn't leak a drip! I was out driving today and the low oil light came on. I checked it and it was 1 1/2 quarts low. No oil leaking anywhere. Now last week we went for a cruise and ended up racing, oil was checked and was perfectly full. I did hit the limiter accidentally twice but it runs just perfect still with no problems. Any help would be greatly appreciated!
Old Nov 6, 2014 | 08:53 PM
Drag0's Avatar
How many miles does the car have ? Also did you notice any signs of burning oil
Old Nov 7, 2014 | 06:17 AM
Fier23's Avatar
the car has 58200mi. No signs of burning. However the last 1500 miles I've driven her very hard, Drag racing and multiple 150+ highway runs.
Old Nov 7, 2014 | 08:21 AM
Drag0's Avatar
Yeah that's low miles. Mine has 136k and doesn't burn any oil so yours shouldn't either.
Drive it normal for a couple hundred miles and check the oil again. If its still using oil you should probably change oil viscosity. Something slightly thicker
Old Nov 7, 2014 | 10:41 AM
Fier23's Avatar
if it matters I'm using Royal Purple high performance 5w-30
Old Nov 7, 2014 | 11:00 AM
Furious1's Avatar
I've had similar oil consumption issues with Royal Purple...going to change away from it this time.
Old Nov 7, 2014 | 09:40 PM
Drag0's Avatar
Yeah change to mobile 1 or something similar.Not all cars like the purple stuff.
Old Nov 8, 2014 | 10:52 AM
BubaGumpShrimp's Avatar
You're probably sucking it up threw the pcv valve, take the air lid off and open the throttle body and look for oil. this is a known issue and many install a catch can. Some dont suck up as much but other motors will drink it like cool aid..
Old Nov 9, 2014 | 09:00 AM
01Z0H6's Avatar
Yeah, Blow by happens when you drive the car hard... Had a similar issue w Blow by whereas oil was leaking from my air filter... ( catch can routed).. so I installed an oil separator, in addition to my catch can... Problem solved...
