Overheated after running out of water. Water disappearing? Input needed!!!
Save the manuals!
Some of the larger chains will offer free pressure check as a leader item. Check at O'Reilly or Advance to see if they have one on the loaner tool program.
The vacuum plug to cover the LT1 bypass port isn't designed for hot coolant, and is likely why it is failing. Get a high temp cap made for heater hose return ports from a radiator shop/parts house, or use a 1/2" brass dowel pin and Devcon two-part epoxy.
