Overheated after running out of water. Water disappearing? Input needed!!!
Yesterday morning omw to work, temp gauge reads max and oil pressure nearly flat lines. SES light is on and still dont know what it is. Car ran like death for a few seconds before i turned off to cool. Let it cool and added water and seen it is leaking from a hose cap (I have a manual). Sadly, and maybe even a bit ridiculous, it is the newest component of the cooling system. Where do they get this crap from?
Before leaving work a friend wrapped plastic hose around it and I have yet to see it leak any at all since. Once he did this I topped it off and it seemed to run and drive just fine.
This morning I added half a gallon to the radiator. I thought no surprise just the system burping.
So after work today I decide to check the water level again just to be sure. This time I was able to put in nearly a gallon. Does this sound okay? Do I need to worry about something else now? Im even more worried now cause after topping it off I see air bubbles coming up... nearly in a pattern. See video;
Save the manuals!
So, you saw water leaking from the pressure cap? Is it a GM pressure cap or aftermarket?
That cap should retain the pressure and only bleed it off when there is excess. Typically, as the fluid expands with the car heating, it will let fluid move to the reservoir to relieve that pressure. When the system cools, a vacuum is developed and the cap lets fluid flow back in to the radiator.
How is your reservoir levels through all this?
When you really run the heads and block out of...or low on coolant, it takes a lot to refill it. While its idling like that....squeeze the upper radiator hose rapidly like 10-20 times.....That pushes the air bubbles past the t-stat. Also, give it a sharp rev by moving the TB with your hand when its bubbling like that, it should also push coolant up against the tstat and help push air through it.....and also drop the coolant level down. If it drops down...theres still air in there somewhere. Once you see the coolant level drop way down out of site....refill it quickly before the tstat closes again. If you do that 2-3 times the system will be full......
The coolant would just drain right out of the radiator in about 1 minute.
Here's what I did with that extra port.........put a 6 inch piece of heater hose on it with a clamp....makes a great and FAST pouring drain line. Never use that cheesy petcock drain again. Lets me flush very fast.
......what do you mean it was leaking from that bottom port....???? Were you driving around with that port totally OPEN....????
really like that setup. trying to figure out what you used.
5/8" piece of heater hose....6 inches long. Then go to Home Depot and find a brass threaded plug that will screw into the end of the heater hose. Then a clamp on that end of the hose to secure that end with the brass plug screwed into it. The brass plug will stick out enough to get a crescent wrench or open end wrench or plyers onto it to tighten and loosen it.
The white plastic cap in my picture worked perfectly too. It was threaded and screwed into the end of the 5/8" heater hose. I just got a brass plug later.
When I want to do a flush I loosen the clamp a little bit...then with a crescent wrench or plyers....spin the plug out of the hose end.
I did that once with exactly the same cap and clamp........it popped after about 2 months when I pushed on it with a screwdriver........it was all cracked and bulging. Not gonna last long.....
And it absolutely needs a clamp....18psi will push it off in about 15 minutes after engine start.
This time it was to work, back from work, and to work again before I checked fill level. Only had to add just a bit;
But, I see this;
http://www.use.com/Btmvr
But, I see this;
