Missing Racetronix Connections?
For 2001 Pontiac Trans Am
Purchased the RFPK-001 which includes harness FPWH-017 and RCS-028. I am trying to figure out if I am missing connections to the stock harness. Included are pictures and referenced this previous thread: http://www.racetronix.info/showthrea...=stock+harness
but still cannot figure out how the stock harness connects. Does the stock connections get omitted? If so how would the pump be triggered on? From the end of the harness it has a square four-pin and straight four pin then goes down to the relay, nothing in between to connect the stock harness. Suggestions?
The end of the harness will bulkhead connections which I assume connects to the fuel bucket.
The relay with the connections at the end of the harness against the factory bulkhead connection.
The factory bulkhead connection alone.
The Racetronix harness from relay to end. It also has the boost-a-pump connection which does not mate up to any stock harness connections.
Looks like you got it all. This picture would have been handy to have a couple of months ago when I did my install. I thought for sure I was missing a connector since Racetronix does not give any instructions, and they take 3-5 days to approve your account to be able to use their forum. Useless.
Photos in the below links:
https://ls1tech.com/forums/general-m...el-sensor.html
http://cimg2.ibsrv.net/gimg/ls1tech....e22d8cc4aa.jpg
