Look at these alignment specs!!
Left
camber -0.8
caster 4.5
toe before .08
toe after -0.03
Right
camber -0.9
caster 4.1
toe before .09
toe after -0.03
Cross:
camber 0.1
caster 0.3
total toe -0.6
thrust angle -0.23
When I brake at highway speeds it's all I can do to keep it in it's lane. The steering wheel moves back and forth on the highway as well. I would say it's in the rack and I should adjust it but it's already very tight to steer.
Any comments on those alignment numbers?
After owning this car for 14 years, I've never hated it more than I do now. I wanted to blow it up when I got home.
Left
camber -0.8
caster 4.5
toe before .08
toe after -0.03
Right
camber -0.9
caster 4.1
toe before .09
toe after -0.03
Cross:
camber 0.1
caster 0.3
total toe -0.6
thrust angle -0.23
Your alignment is ok... I think the problem is worn out or broken suspension parts.
I disagree about the alignment being "OK". The car should have more caster, to start with, and the right side should have about .3-.4* more caster than the left side, to account for "pull" due to road crown. When I had my '96 Z/28, I ran with 5.5* caster on the left, and 5.8* on the right. Secondly, if it were my car, I'd want about .02* of toe IN.
Normally when you hit the brakes and the wheel starts to shake like that it's either rotors, ball joints or control arm bushings. A loose rack can do that too however the car will feel "floaty", slow to respond or when you turn from one direction to the other even though you are turning the wheel the car is trying to go the other way due to the slop in the rack or bad bushings.
If the OP was describing was a hard pull or drift it would be alignment or tire related.
You don't need that special tool to adjust camber. All you need is a pry bar and some common sense.
There is something loose or worn in the front. I think if someone drove this thing, they would tell me to park it until things are resolved. There is play and a lot of twitching of the wheel on the highway, the rack is also much tighter than I like, the rear feels very sloppy. I'll be under it tomorrow and will checking everything.
I've also double checked the intermediate steering shaft. Time to get under it and check everything.
. Time to get with the Rack Doctor.
