Sponsored by: CARiD
alternator bad?
Old Jun 6, 2004 | 11:12 PM
stone150's Avatar
Default alternator
what arte some sighns of a bad alternator in an LT1?
Old Jun 7, 2004 | 05:53 PM
dhdenney's Avatar
Pop your headlights, turn on the radio and A/C and see if your voltage doesn't drop. If it doesn't, then you're good to go. If you're out driving it and asking this question, then you have no problem. If you turn on all your accessories and it kills the car, then you won't be starting the car again because you'll need a new alternator. The battery will be dead with nothing to charge it.
Old Jun 8, 2004 | 12:30 PM
LT1 Guy's Avatar
Hmm... what if you're at a stoplight in idle, and it dips into the yellow and stays there until you start accelerating again? My turn signals don't blink as fast when that happens.
Old Jun 8, 2004 | 12:39 PM
dhdenney's Avatar
Good question. I don't know, mine doesn't do that. I always thought your alternator was either dead or working--nothing in between.
Old Jun 8, 2004 | 12:51 PM
Vendetta's Avatar
Another typical sign of a faulty alternator is varying intensity of the headlights. One second they'll be normal, the next, they'll flicker from very dim to off.
Stone150, please reduce your sig pic size to under 500x150. Thanks.
Old Jun 8, 2004 | 12:55 PM
LT1 Guy's Avatar
Okay... then maybe I don't have a faulty alternator. But the yellow in idle is causing me some grief. My blinkers flash really slow and I keep thinking everything electrical is going to die on me. However, when my car is idling in neutral, the needle is where is should be. Would it have something to do with my battery? I've had to replace my battery 3 times in 2 years because of burnt terminals.
Old Jun 8, 2004 | 01:44 PM
Mikey 97Z M6's Avatar
Do you have underdriven pullies? Does the voltage come back up when you rev the engine?
Mike
Old Jun 9, 2004 | 01:25 PM
LT1 Guy's Avatar
No underdriven pullies. The voltage does come back when I rev but then settles into the yellow when I take my foot off the gas.
