Sponsored by: CARiD
'98 Front wheel hubs
Old Feb 3, 2016 | 12:12 PM
Mr Rich's Avatar
Default '98 Front wheel hubs
I've been wondering; how long is the life of the front hubs? I replaced the engine and trans over four years ago. Those parts will be good for life at this rate. I've got 150K on the chassis and hubs and 25K on the engine and trans. I'm thinking about replacing them as PM and just wonder if anyone has additional thoughts. I recently replaced the gear oil in the rear diff and it was remarkably clear for the miles. It did make a difference with the clutches in the rear since I don't hear noises during parking now.
Old Feb 3, 2016 | 06:02 PM
blue09rocket's Avatar
well my car is 15 yrs old and only 81000 miles, and right before I put the car away in my garage for the winter, I started hearing a hum coming from the front end, you guessed it front left wheel hub. Knowing me just like you in doing preventative maintenance, Ill probably replace both driver and passenger sides at the same time. Only thing that sucks is AdvanceAuto and the like has them for around or just under $100 per while GM has some for over $200 per! Im always a little worried when it comes to the quality of Advance parts over OEM.
Old Feb 3, 2016 | 08:49 PM
wssix99's Avatar
Save the manuals!
The front hubs can be variable. It's not uncommon for them to start making noise at 75K miles. Any distance beyond that on the OEM hubs is gravy.
Old Feb 3, 2016 | 11:10 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
The highest mileage 4th gen I've had was ~110k miles, and there was nothing wrong at all with the original hubs. I wouldn't replace them unless there is an issue.
Old Feb 4, 2016 | 12:59 PM
Cpt.Derrek's Avatar
What I have learned is that with stock Offset tires the hubs will last a long time well over 100k but if you run offsets that put the load uneven on the hubs the bearings life is significantly reduced.
Old Feb 5, 2016 | 10:39 AM
also forgot to add that if I let go of the steering wheel, car pulls slightly to the left.
Old Feb 5, 2016 | 01:49 PM
wssix99's Avatar
Save the manuals!
That's an alignment issue.
No worries with this part. GM doesn't make them. They wrap their box around someone else's part. As long as you get a well known bearing manufacturer, you can ride with comfort and confidence. SKF, Timken, NTN are all top names. One of those companies likely made the parts on your car when it rolled out of the factory.
BTW - (I found out the hard way!) If you aren't aware, AC Delco is not always "GM" and GM may offer a different part than Delco these days.
Old Feb 11, 2016 | 06:53 PM
Daniel Richards's Avatar
I had like 180k to 190k on the stock ones on my car, replaced them just for the sake of replacing them as part of my overhaul of the suspension.
Old Feb 12, 2016 | 01:28 PM
M4N14C's Avatar
Depends a lot on how you drive. F-Bodies eat front hubs if you autocross them.
