ANY reason (indie) shops charge
Mike Norris of Norris Motorsports put my entire car together when his shop was in Orlando...everything you see in my sig went in at one time back in 2002...except it was a 436ci stroker engine originally. I paid exactly that amount, not a penny less or a penny more.
I got a quote for LABOR HOURS required to complete everything...every items was listed on the quote and how many HOURS each part or project took to complete. Then it had a labor hour total at the bottom.
If I was standing there the entire time watching, and it took 3 hours less, I would not pay for those 3 hours....I would pay my bill and drive away. I wouldn't drive away and keep paying for 3 more labor hours that are NOT being done.....lol.....Thats just plain stupid....
Who the hell does this....????
Shops give you a quote for the entire job and when you agree to pay it, they do the work. The labor hours are a part of it yes, but like I said, if that's the what they quoted you, that's book time, you don't get to decide how much of it you're actually gonna pay.
I would pay the shop hourly rate....for the exact amount of time it takes to pull the engine. Not some ridiculous estimate out of a book that every one of us KNOWS is complete BS. If a mechanic at any dealership in this country actually took as long as the book hours say it does to complete each job....they will get fired.
Any shop that CANNOT remove an engine with a lift and every tool needed......in 2-3 hours....they are not that good.
It is the "book" that is the rip-off, not necessarily the shops.
The dealers will tell you that according to the 'book' the WHOLE rear axle MUST BE dropped to get the tank down for a fuel pump change.
When the dealers do this they DO NOT drop the axle at all.
I just looked up flat rate times on alldata. 16.2 hrs to replace a complete engine, 21.2 to replace a long block.
$100/hr is pretty typical labor so $1600 isn't unreasonable, and it's definitely not high if they are replacing just the long block.
It might seem high but you'd have to understand why shops charge the way they do. Can you get a guy to do it cheaper in his garage? Yeah, but if you want a professional shop to do work, expect to pay book time and a typical hourly rate.
^^^Yes, even Hawks T.G., (as much as they are hated by most on here) only charges ~$1200.00 labor to R&R an engine in these cars.
They are also very reasonable on their asking prices for used LS1/6 long blocks and complete engines.
I did find a local (f body tuner) shop which only charges $1050.00 for this job.
Dealers and indie shops rarely ever see performance cars. I've never had a 4th gen f-body brought into a shop I worked for. So there's no way they could know that the book time is high, and if the tech has never removed an engine from a 4th gen, he's not going to do it as fast as a shop that specializes in them. Like I said, book time is 16 hr to remove and replace the engine. Depending on area, indie shops are $80-$100/hr, dealers are $100-$150. $1600 to R&R your engine is exactly what I'd expect a shop to quote.
Another thought to consider. The tech may only see 20-25% of that $80/hr anyway. So good thing the book calls for double the time i'm going to take on it.
We've all had those jobs that we finish in half the time, followed by those jobs that for one reason or another everything goes wrong.
Another thought to consider. The tech may only see 20-25% of that $80/hr anyway. So good thing the book calls for double the time i'm going to take on it. We've all had those jobs that we finish in half the time, followed by those jobs that for one reason or another everything goes wrong.
The only way around it is to pay **** $10/hr labor under the table, and that's why businesses are leaving Ca.
So (2) hourly workers at $20 a piece will cost the owner $100 per hr just to have them.
Lol learn to work on vehicles is what I said to myself after getting a $2,000 quote to do a cam swap back in 05' when I started this hobby
I just got a quote to change out an oil pump and o-ring seal for AT MOST $500.00 for labor.
The dealer wanted close to $1500.00 (labor only) for the same exact job, and most LSx tuner shops want ~$1200.00 (labor only).
Granted, like the posts above bring up, the first low quote is a small shop, with low overhead, and the owner does most of the work, with help from one or two other techs.
