Sponsored by: CARiD
LS1 / LS6 PCV system (connected up wrong?)
Old Oct 19, 2016 | 05:08 PM
TheNutDriver's Avatar
Default LS1 / LS6 PCV system (connected up wrong?)
Hi all,
I'm currently trying to fathom out how my PCV system should be routed on my 2001 LS1.
It has an LS6 valley cover fitted by a previous owner but it seems the built in PCV part has never been used. The pipe which exits the valley at the front of the cover is still blanked off with a red stopper. I have a pipe coming from the throttle body top connection which goes to the vent pipe on the passenger side valve cover and a larger hose coming from the intake port to a PCV valve and then a larger hose which travels along the passenger valve cover, splits into two at the back of the engine - 1 smaller tube goes somewhere I can't see and the othernone connects to a fitting on the back side of the drivers valve cover.
To make use of the LS6 valley cover, how should I be reconnecting the pipes up?
Old Oct 19, 2016 | 07:19 PM
Ok so I think from reading as much info as I can that I need to do away with the PCV valve itself, connect the manifold vacuum port to the LS6 valley cover port and connect both the drivers side and passenger side valve covers to the throttle body port.
Does that sound correct?
Old Oct 19, 2016 | 07:34 PM
Majestic9C1's Avatar
this is all thats needed for the LS6 PCV setup
small hose going from valley cover port to side of intake manifold along with the hose that goes from throttle body to passenger valve cover..
any other ports can be plugged
Old Oct 19, 2016 | 07:55 PM
Excellent!
Thanks for the advice and photo. I'll get it sorted now!
Kind regards
James
Old Oct 21, 2016 | 07:38 AM
jaxcam02's Avatar
yea just go to ebay and search for " LS6/LS1 Corvette Camaro Vented Valley Cover PCV Hose"
Make sure you save that red nipple from the LS6 valley cover. Use it to cap off the PCV port on the passenger head. There's also a plug you need to buy to plug up the driver's side head. Ill try to find the part number right fast.
Old Oct 21, 2016 | 07:41 AM
jaxcam02's Avatar
http://ls1howto.com/index.php?article=18
plug GMPN: 12568011
Old Oct 21, 2016 | 05:49 PM
Thank you!
Just ordered the plug from summit racing and should be here within 2 weeks! (I'm UK based)
I have some spare fuel hose which I will use for the connection to the valley cover.
You've been a great help
Old Nov 2, 2016 | 11:28 AM
MIGHTYMOUSE's Avatar
some early ported valley plates do not have pcv built into them and still require the external pcv valve. you should verify this since you did not buy the plate yourself.
see this gm image of the valley port and an external pcv valve on some year cars
a test would be to remove your oil cap and hook hose to the valley plate, blow into it
if it is extremely difficult to blow into, it has the built in restriction, if it is similar to blowing through the tube itself then you should keep your original valve in-line
 Michael S. Palmer
Old Nov 2, 2016 | 12:57 PM
Thanks for this advice I'll be sure to do that check
Old Nov 25, 2016 | 05:04 PM
I finally got round to doing the above test and it was practically as easy to blow through the tube connected to the valley plate port as it was blowing through the tube on its own so I am going to use the external PCV valve. Does this method offer any advantage over the stock setup? if not then I wont bother to alter it.
Old Nov 26, 2016 | 03:53 AM
kingtal0n's Avatar
I am curious, where is the fresh air source for the crank case?
Is the throttle body port pre-butterfly, sourcing fresh air from the intake filter side? if so, the intake manifold pulls on the crankcase through one valve cover, and pressure drop is transferred to the other valve cover through the crankcase, which makes its way to the throttle body port? That is a Stock route?
Old Nov 26, 2016 | 08:54 AM
The fresh air source or "breather" is the tube from the throttle body to the passenger side valve cover. The contaminated blow by gases exit through the PCV valve in the valley plate to the intake manifold port.
At idle, intake manifold vacuum is high and so there is little to No flow through the PCV system as the vacuum pulls the check valve against its seat (against the spring tension). As the engine revs higher the vacuum drops and so the PCV check valve begins to open allowing the limited manifold vacuum to pull gas from the crankcase into the intake manifold and thus drawing fresh air in from the breather. At high throttle levels/WOT the PCV is fully open and the blow by pressure itself forces the air out of the PCV system even though there is virtually no vacuum at all.
The stock PCV routing is different to the image. The PCV valve is connected to tubing which draws gases from the drivers and passenger valve cover and the breather is also on the passenger valve cover.
Old Nov 26, 2016 | 12:19 PM
kingtal0n's Avatar
If the valve is shut during vacuum, and opens as pressure increases, then it would be open during boost. Is this a special kind of pcv valve? It sounds backwards from every pcv valve I have ever heard of, which are generally open during high vacuum and shut during boost.
It seems very odd the pcv valve would be shut during idle. I think it is a special kind of valve based on what you are saying here. Any pictures of it?
Out through the pcv valve, and into the throttle body? So if I apply boost pressure to the throttle body, I pressurize the crank case.
It is a new thing you are showing me, I do not doubt you I only wish to explore this further if possible. Will the FSM show me this special pcv valve?
Old Nov 26, 2016 | 12:33 PM
no it's not a special kind of PCV valve. That's how they work.
I dont recall any body talking about a boosted set up here. This is normally aspirated.
Old Nov 26, 2016 | 12:38 PM
I said at idle "there is little to no flow" not that it was fully closed. At idle there's less blow by gas being produced...and to have the PCV valve fully open at idle would be like having the port in the intake manifold open to atmosphere (or equivalent to a large vacuum leak.)
There are extensive websites detailing all of this information for both N/A and Turbo or Supercharged applications.
I just want to know if the valley port with external PCV valve offers any improvement over the stock setup as my ported valley does not have the built in PCV provisions.
Old Nov 26, 2016 | 01:12 PM
If your ported valley cover doesnt have a built in PCV than you need to add one to the small hose going from valley cover to intake manifold.
Old Nov 26, 2016 | 01:34 PM
Yes I have one ready but wondered if that kind of setup offers any advantage over the stock setup?
Old Nov 26, 2016 | 03:50 PM
just cleaner looking and wont get as gunked up as the long lines running around the top of the engine tend to get after a while
Old Nov 26, 2016 | 03:53 PM
Ok thanks.
I shall get a catch can as well then.
Old Nov 26, 2016 | 03:59 PM
not to mention that the stock LS1 PCV is built into that long hose and that long hose is over $100 to buy
