Sponsored by: CARiD
Wiper fluid spray pattern
Old Nov 8, 2016 | 02:54 PM
JimMueller's Avatar
Default Wiper fluid spray pattern
The windshield sprayer on my driver side doesn't seem to be spraying properly. It doesn't spray far enough to the drivers edge of the window, and as a result, that arc of wiper arm travel just gets smeared. Is there something I can adjust or clean?
Old Nov 9, 2016 | 06:52 AM
wssix99's Avatar
Save the manuals!
You can google a lot of remedies for this but some are bad. (like sticking a pin in the nozzle)
I've had grit get in nozzles of other vehicles and had success by taking the nozzle off the car and using a MightyVac to suck clean water backwards through it. I'm not sure how easy it is to get the nozzles off our cars, though. You could also leave the nozzle on and build a "cup" of water around it with tape to suck some fluid back through the tubes.
Old Nov 13, 2016 | 09:06 PM
blue09rocket's Avatar
gm part # 14098191, both sides are the same, I replaced mine awhile ago, don't remember exactly how I did it, I'm pretty sure you have to remove the wiper cowl to get to the nozzles. Make sure the washer hose is firmly attached to the nozzle, when I was replacing mine I found out mine was loose, causing it to not spray a lot of fluid on the windshield. But I figured since I had the cowl apart, might as well replace the nozzle. works great now.
Old Feb 1, 2017 | 02:47 PM
JimMueller's Avatar
I ended up replacing both nozzles and the behavior remains the same. Could it have anything to do with my choice of wiper fluid or wipers? With or W/o Rain-X, etc?
Old Feb 1, 2017 | 05:32 PM
BrittleSpeed's Avatar
Maybe theres some junk in one of the t's or the line somewhere. Can't see a reason why it wouldn't spray right with new nozzels.
Old Feb 2, 2017 | 07:20 AM
wssix99's Avatar
Save the manuals!
Is it related to the angle the spray is hitting the windshield? I just put mine back in and it isn't pointed down at the window at the right angle. I need to fix that.... Hopefully it will make the spray pattern better when I do.
Old Feb 2, 2017 | 11:57 AM
JimMueller's Avatar
The nozzles fit pretty snug in the cowl, not sure why they'd be at the wrong angle unless the cowl was misaligned. I don't recall ever having the cowl off but the dealer may have when it was under warranty.
Old Feb 2, 2017 | 01:40 PM
wssix99's Avatar
Save the manuals!
How did you get the nozzles out without taking the cowl off?
Old Feb 2, 2017 | 02:27 PM
IIRC, I took all the plastic things attaching it off, was able to lift it up, not a lot just enough to get under there and get them, didn't feel like taking the one wiper arm off. Oh and I think I had to remove the cowl seal too. I also looked at he new nozzle as how it gets attached and detached.
Old Jun 9, 2024 | 03:37 PM
JimMueller's Avatar
I had the same thing happen with my passenger side wiper nozzle today. I've never had the cowl off before, but I was able to replace the driver side nozzle some how in the past (and it still sprays great).Today I tried thin paper clips and a push pin; while they would go in, I couldn't get the spray pattern corrected.
Similar to the way I remove power window controls, I used a pick on one side to pop up the clip, then ran the pick around the perimeter to release the other clip. However, it didn't have as much free play as the driver side had. It has a 90* elbow between the nozzle and the feed tube. While trying to remove the elbow, it came off the hose With the design now known and with a little more care, I think I could have done it without it pulling off the hose. Alas, I'm pulling at least the cowl today.
Old Jun 9, 2024 | 05:08 PM
JimMueller's Avatar
Passenger side was easy. I removed the retainers for R section of cowl so it was completely loose but still under L cowl. Attached elbow to new nozzle, oriented new nozzle same as old and snapped it in. Then slid my hand under loose cowl and reconnected hose to elbow. Then reverse.
The new nozzle sprays against the wiper arm until the arm moves... but after it moves coverage is fine. Not sure if its worth messing with it further.
https://www.dropbox.com/scl/fo/bya08...0pt4ysmal&dl=0
