replacing the 4 torx screws for the throttle body - LS1?
I was trying to replace my throttle body with a ported one but got hung up on the last T20 Torx bolt on the sensor.
I just bought a screw remover/extractor on amazon but Im going to need to replace it. I might as well do all 4.
What size screw? Should I go with an allen screw?
Hope the extractor works...
To make it easy you could just bring the bolt thread you are looking for to a hardware store and they usually have boards you can screw the bolt into that are labeled
Still could not get the screw out...
- used a grab it remover
- used drill bits to try and create a deeper hole to remove
Next option - dremel?
I just need it for the sensor .
