Sponsored by: CARiD
Power steering rack leak
Old May 1, 2017 | 08:23 PM
lildemars09's Avatar
Default Power steering rack leak
I have a bad leak coming out of the power steering rack where the steering column connects to. My question is can i replace that top seal or do i have to replace the whole rack? Thanks guys. I have the FE4 also if that helps.
Attached Thumbnails Power steering rack leak-20170501_192504.jpg   Power steering rack leak-20170501_191332.jpg   Power steering rack leak-20170501_191423.jpg
Old May 1, 2017 | 08:35 PM
RockinWs6's Avatar
I'd simply replace the fluid and add 2 ozs of TransX, should fix it right up.
Old May 1, 2017 | 08:36 PM
Isnt that stuff bad for your rack?
Old May 1, 2017 | 08:39 PM
Also isnt that for trans fluid?
Old May 1, 2017 | 09:14 PM
I also failed to mention, its leaking pretty good. Its not a slow leak.
Old May 1, 2017 | 09:42 PM
steering_experts1's Avatar
We can rebuild your rack and return it to factory specs.
Old May 1, 2017 | 09:43 PM
Whats the cost? How long for build/return?
Old May 1, 2017 | 10:39 PM
thatoneguybriz's Avatar
Pull the rack and have it rebuilt or buy a reman unit.
Old May 1, 2017 | 11:17 PM
RockinWs6's Avatar
Yes its TERRIBLE don't do it! ...................LMAO
Old May 2, 2017 | 06:23 AM
Rebuilding services for your rack start at $250 and the turn around time right now is about 1-2 weeks.
Thanks,
Junior
Old May 3, 2017 | 08:50 AM
Red4Mula's Avatar
Or you can buy a rack for under $190 from Detroit Axle. Mine was also the FE4. I received mine in 3 days, looked really good out of the box, everything lined up perfectly, and the bushings were good. They don't charge you a core, and will give you $25 plus a lifetime warranty if you send them your rack with the prepaid label that's included in the box. Mines been running great.
Old May 3, 2017 | 11:10 AM
how long have you had yours?
Old May 3, 2017 | 11:22 AM
Red4Mula's Avatar
Oh, about two months now. No leaks, sounds, or anything else odd so far. Feels good to have tight steering again.
