Sponsored by: CARiD
Valvetrain noise
Old May 9, 2017 | 12:19 PM
APG12's Avatar
Default Valvetrain noise
I've got a 99 Trans Am that's been sitting for about 4 years. I finally got it running and I'm trying to get it back on the road. I did an oil change a couple days ago using mobil1 5w-30. Since the oil change, the valvetrain has been especially noisy. Sounds like more on the passenger side but I even here it out the exhaust.
I have a couple YouTube videos that I am trying
APG12's Avatar
Clearly I have no idea how to upload a video.
EDIT: got them
Old May 9, 2017 | 04:00 PM
RockinWs6's Avatar
How much air is in the oil? Check the dipstick for tiny air bubbles. If its full of bubbles most likely the oring has shrunk and is letting air inti the oil. This will cause a noisy valve train.
Old May 9, 2017 | 04:43 PM
APG12's Avatar
No real bubbles from what I can see.
Old May 9, 2017 | 06:48 PM
RockinWs6's Avatar
Look carefully, they are very small but would be a lot of them. If nothing then I would say from setting the lifters are gummed up. You could try some ATF 6-8 ozs added to the oil to clean them up. OR I like TransX, although its intended for used in Auto transmissions it works fantastic for cleaning up the lifters and sealing the oil pump.
Old May 9, 2017 | 07:12 PM
APG12's Avatar
Yea the oil looks good. Maybe the lifters are gummed from it sitting and not running for so long? I didn't notice the sound before the oil change, but I didn't run it for long on 4 year old oil.
I'll try the ATF. How long should I keep it in before I change the oil again? I was thinking about seafoaming and doing another oil change but maybe I'll hold off on that.
Old May 10, 2017 | 06:58 AM
jaxcam02's Avatar
Whats your oil pressure gauge say when its on?
Old May 10, 2017 | 07:16 AM
Darth_V8r's Avatar
Moderator
I recommend AGAINST putting seafoam in the crankcase.
Old May 10, 2017 | 07:28 AM
chrysler kid's Avatar
I've done it on the wife's trans am, it had 80psi cold oil pressure and 60 psi warn pressure.
Added sea foam to crank case, drove the car for q5 minutes, changed the oil and filter, and the oil pressure went back to normal.
I generally prefer marvel mystery oil though
Old May 10, 2017 | 07:52 AM
APG12's Avatar
It reads about 60 but my gauge cluster doesn't appear to be working properly so I don't trust the numbers.
Old May 10, 2017 | 07:54 AM
APG12's Avatar
The problem with the seafoam is that I can't drive the car much to work it in since my 10 bolt is shot. I'm limited to idling in the driveway or driving up and down my block.
Old May 10, 2017 | 08:52 AM
Darth_V8r's Avatar
Moderator
Ls1's are known to do that. Lol. Sorry to hear.
Old May 10, 2017 | 09:47 AM
APG12's Avatar
Yea and trying to find a decent replacement has not been easy.
Old May 10, 2017 | 07:22 PM
RockinWs6's Avatar
Forget the SEACRAP unless you like spending money on an engine. Seafoam can cause big damage used in the oil, the only way I would use it in the oil is at a idle and NOWAY in LS engine I wanted to keep.
You can leave the ATF in BUT I wouldn't run the **** out of it while its in there. I'd use 6-8 ozs of ATF and 3ozs of the TransX together. Let in there for ay least 2k, if the lifter internals are crapped up it should clean them up. I had great success with it. I usually add this with a fresh oil change.
Old May 10, 2017 | 07:42 PM
APG12's Avatar
I'll give it a shot. Thanks for the help!
