Sponsored by: CARiD
Where does this cable go??
Old May 21, 2017 | 11:10 AM
camar0rs's Avatar
Question Where does this cable go??
I was replacing my alternator this morning and noticed this cable which appears just laying on the frame... where is this normally mounted? I am assuming a ground?
2000 trans am....
Old May 21, 2017 | 02:12 PM
Phoenix'97's Avatar
Post
2000 trans am....
Yes this is definitely a ground, although since you have an LS motor I can't really tell you where exactly it is was originally attached. Can you show us more pictures of this ground wire from as far back as you can trace it and any areas of the car to use for reference? If you can get more pictures for us, hopefully someone can check their LS bird out and answer your question as to where it goes to be screwed in.
Old May 21, 2017 | 02:18 PM
Phoenix'97's Avatar
Exclamation
2000 trans am....
Would this help? I did a quick google search and one of the diagrams may be your ground wire location.
https://ls1tech.com/forums/stereo-el...locations.html
Old May 21, 2017 | 02:47 PM
Phoenix'97's Avatar
I think I found it...
Old May 21, 2017 | 04:42 PM
abbas461's Avatar
ground wire
Old May 21, 2017 | 05:35 PM
camar0rs's Avatar
so i moved the wire around more and the other end was not far... so neither end is connected...
the shielded cable also was just hanging around.... needs to be resecured
Old May 21, 2017 | 05:36 PM
camar0rs's Avatar
The shielding wire it was taped to, which i traced back some, went to the o2 sensor... maybe this was one of the spots it could have been connected to ?
picture is laying under the driver door looking up
Old May 21, 2017 | 06:47 PM
01ssreda4's Avatar
Mine goes from the frame rail under the fuse block and I think I have it on one of the alternator mounting bolts.
Old May 22, 2017 | 10:28 AM
chrysler kid's Avatar
Correct, it mounts between cylinders 6 and 7 on the drivers side behind the alternator, and mounts to the side of the frame rail under the fuse box.
It is an engine ground cable, or engine ground strap
Old May 23, 2017 | 04:22 PM
camar0rs's Avatar
Please see attached pictures and see if this is correct...
As for the frame location, is the red arrow where the other end was supposed to be? the bolt size appears to be the correct size.....
i did see this: G109 Left front frame rail, forward of the brake pressure modulator valve bracket (cruise control, also links to G111)
this is looking down from driver side fender at alternator....
New alternator does not use the back bolt but was this where it originally was?
i found this but i couldnt find another spot: G111 on the left side of the engine, behind the alternator, below exhaust ports (ground link to G109)
Old May 23, 2017 | 08:06 PM
Here ya go
The other ground cable at the chassis should have both points attached
Originally Posted by WhiteBird00
G111 is a bolt that goes into the engine block on the left side just behind the alternator:
Old May 23, 2017 | 08:54 PM
camar0rs's Avatar
Awesome picture, thanks!
so you cannot see this from top side so here is pic looking up from alternator, and looks like this is it.... looks like bolt hole is M8 x 1.25 and threads appear only 3/4 deep... i had a 1" on my bench and stopped about 1/4 still out.... naturally.. so a 1/2 or 5/8 bolt should work good...
Old May 24, 2017 | 06:58 AM
No. That spot is for the rear alternator bracket. The ground goes from the engine block to the frame
Old May 24, 2017 | 07:06 AM
camar0rs's Avatar
i think you were commenting on a previous picture, last picture was of the engine block
Old May 24, 2017 | 08:00 AM
Oh I see it now, yeah it just needs to be a clean point on the block
Old May 24, 2017 | 08:48 AM
camar0rs's Avatar
thanks again for help! i have it hooked up.... went with 1/2" m8 x 1.25 bolt
Old May 26, 2017 | 01:02 AM
eb110americana's Avatar
Looks like you got it, but here is a link to my photos just the same. I went and made a new ground strap, as the stock one is weak and it sucks.
https://ls1tech.com/forums/generatio...l#post19531489
