Sudden terrible running.
You have a car that has been sitting for 5 years. You did zero maintenance in light of the extended sitting(?). You started driving it. It ran poorly, but you kept driving it. Then the SES light was flashing (which is serious - you have misfire condition that can damage your car). You did nothing. You kept driving it. It threw a handful of codes. You ignored them and kept driving it. It did all that again, and you did nothing and kept driving it.
Um... Maybe try starting with the codes man.
p0200 is an injector control circuit malfunction, this could be triggering or triggered by your p0308
p0332 is a knock sensor code, probably triggered by the other two codes.
Check your injector wiring, paying special attention to cylinder 8, look for broken wires, corroded connectors, etc. You may also have a stuck injector or failing injector. I've seen them fail intermitantly before and can kind of be a pain to chase down, this may be what you are experiancing. Also check out the plug wires, make sure you don't have one arcing etc..
1) Inspect your wires
2) Pull an easy plug and:
a) See if it is indeed new
b) See if it is the correct plug for the car
3) Change your fuel filter!!!
Speaking of the fuel filter...did you drain the gas tank? Or are you running on 5 year old gas?
