Sponsored by: CARiD
Front right turn signal
Old Jun 20, 2017 | 10:12 AM
captian kirk's Avatar
Default Front right turn signal
On my 98 Camaro all the turn signals except the right front works (blinks). The right front stays on and does not blink. I replaced the bulb and bulb socket, ant ideas?
Old Jun 20, 2017 | 02:08 PM
Docrocket1967's Avatar
Only other thing it could be would be your rear bulb for your turn signal is blown
Old Jun 20, 2017 | 02:09 PM
Or could be a short in the new socket.
Old Jun 21, 2017 | 06:45 AM
wssix99's Avatar
Save the manuals!
^ Neither of these two is the most common issue.
If you search the site in this section and in the Stereo and Electronics section, you'll find the answer and a way to test for what exactly the problems is. (Hint - try your Hazards.)
Old Jun 21, 2017 | 01:53 PM
Ive never had an issue with the hazzards, with the situation he is dealing with ive only had the issue where the rear bulb was blown and it caused the front not to blink on several occasions
Old Jun 21, 2017 | 10:51 PM
j498's Avatar
Seems like nearly any issue with the circuit can cause this issue. Bad bulb, connection, etc.
I've had this issue and it ended up being a combo of corrosion on the wiring plug going to the front headlamp assembly... and a no so good wire splice on the same wires from the previous owner.
Old Jun 22, 2017 | 07:13 AM
WhiteBird00's Avatar
Ungrounded Moderator
What wssix99 is referring to is the diagnostic practice of turning on the hazard flashers and then walking around the car to determine which bulb isn't working. The hazards will generally flash even when the turn signals don't (separate flasher and different electrical load) so doing this makes it obvious where the problem lies. In this case, it is probably a burned out rear signal bulb which would be easily seen when using the hazards.
Old Jun 22, 2017 | 07:59 AM
Ahhh I see what you mean. When he said that it wasn't the common issue I was surprised cause that has always been my issue with what the OP was experiencing
Old Jun 22, 2017 | 12:08 PM
wssix99's Avatar
Save the manuals!
WhiteBird gave it away. The common issue is a bad flasher. (The hazards are on a different, separate flasher.)
If the flasher isn't a problem, then the hazards will expose where the burned out bulbs, etc. are.
