Fast pace tick or click from undercarriage. . Advice needed
Hey guys looking for a little advice here.. I have 98 Camaro all Bolt ons just installed a built 4l60e an yanks ss4000 converter I have about 100 miles on it.. I was leaving a buddies house an got on the throttle a bit and since then there is a ticking coming from undercarriage. I jacked up the car an in park and neutral there is no noise.. when I put it in drive the ticking increases as speed increases.. so I replaced the u joints so far an that was not it... any ideas?
Found the problem I feel pretty dumb it was the pigtail of a zip tie from the emergency brake cables the end of the zip tie was just barely hitting the weight on the drive shaft making a tick tick tick noise thanks guys for your input another LS problem solved
