Sponsored by: CARiD
Name this fluid!
Old Sep 11, 2017 | 05:53 PM
Greekey's Avatar
Default Name this fluid!
I have noticed this fluid leaking off of my ac compressor! What is it? Is that ac compressor oil?
Old Sep 11, 2017 | 08:52 PM
wssix99's Avatar
Save the manuals!
Seepage from the water pump weep hole. It drips down onto the compressor...
How old is your water pump?
Old Sep 11, 2017 | 08:58 PM
Greekey's Avatar
Water pump has barely 20k on it. This fluid is very oiley!
Old Sep 11, 2017 | 10:18 PM
wssix99's Avatar
Save the manuals!
I suppose it could be compressor oil. The prevailing wisdom that I've seen on that topic has been that if oil is coming out, freon must be also and the A/C performance would be degraded.
Old Sep 13, 2017 | 08:01 AM
biketopia's Avatar
Was going to say trans cooler line seeping but see you have a M6 car. I'd take some brake clean and clean the area up real good and keep driving, obviously make sure all your fluid levels are right. Leaks in the front can sometimes be tricky to find since the fan blowing can disguise where they are coming from. Clean it up real good and then look for the highest point something is coming from, seen way too many guys in shops do rear mains or timing covers when they didn't follow up higher and then it was an intake or valve cover that was actually leaking.
Old Sep 13, 2017 | 08:30 AM
Greekey's Avatar
Thank you. I have checked and checked for anything leaking from a higher standpoint an have absolutely found nothing. It's not engine coolant because it has a thick oiley feel to it. Only thing I can think of is compressor oil or power steering fluid. Really don't know how it can be power steering fluid though.
Old Sep 13, 2017 | 08:33 AM
biketopia's Avatar
PS fluid could be leaking at the rack or a small seep on a line and getting blown up by the fans or air when driving. Check to see if your rack boot is full of fluid.
Old Sep 13, 2017 | 11:42 AM
wssix99's Avatar
Save the manuals!
Just curious - 20k miles, but how many years?
Old Sep 13, 2017 | 11:43 AM
Greekey's Avatar
Less than 5!
Old Sep 13, 2017 | 11:46 AM
biketopia's Avatar
Do you run Dex cool? Coolant that has started to "dry out" can have an oily feel and appearance to it.
Old Sep 13, 2017 | 11:49 AM
Greekey's Avatar
Yes I run dexcool. But I've heard that dexcool is garbage and I could run green. Is that true? If so, I will drain and out green in.
Old Sep 13, 2017 | 01:15 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
No, this is not true. Dexcool is not garbage at all, not in this application (though it was known to react poorly with certain gaskets in a few GM engines - this does not apply to the LS1 however.) You will find that the only folks who have issues with Dexcool in their LS1 cars are those who have let the system run low for a period of time (lots of air mixing in), or those with a contaminated system (such as failed PS coolers causing cross-contamination, use of questionable water, etc.), or those who have failed to follow a proper change interval. I've never allowed any of those three conditions to happen with mine, and I've had zero issues after 20 years (cooling system is 100% original on my '98, other than coolant changes.)
As for the oily leak, it certainly could be compressor oil. One of mine leaked in this way, it was a similar type of oily film. Even with that leak, the compressor/AC system continued to work just fine for quite some time before starting to blow less cold.
Old Sep 13, 2017 | 01:33 PM
biketopia's Avatar
As WS6 stated Dex cool is perfectly fine and the people who claim it's the devil are too lazy to take care of their cooling systems correctly. My duramax has had zero coolant issues since 03 and it's had dex it's entire life. But it's sounding more and more likely that a front seal is letting go and compressor oil is seeping out. Get a black light and shine it in that area, might have to dim the lights in the shop or get some UV glasses and see if it glows, if so you've found your problem. That is if your system has had dye added to it, unless your system has never been touched most oil injected by a shop will have dye in it.
Old Sep 14, 2017 | 08:48 PM
Firebrian's Avatar
I'd look at the AC compressor casing seal for the most likely source of that leak. It's certainly the nearest point. My AC compressor started leaking oil/refrigerant around 12,000 miles and 14 years old. Installed a new Delphi compressor to match what came out. If that's what's needed, you need to replace the LP line/air dryer-receiver + expansion tube.
DexCool in my car since day 1....no issues. I'm pretty sure the original factory DEX was in my car when I bought it at 14 years old. Luckily, the radiator looked fine, and there was no sludge visible.
Old Sep 19, 2017 | 08:03 AM
Greekey's Avatar
Well yesterday I removed ac compressor and it was definitely compressor oil! Nothing was leaking from above! No more ac for me, hardly used it anyway!
