Help with measurement
Can someone without subframe connectors measure the size of the tow hook hole on the unibody side just in front of the rear lower control arm mount? It may be ovalong. It would be greatly appreciated!!!
I want to drill a hole in the same spot through my subframe connector so I can tie it down to a trailer with a mini Jhook.
Thanks!
Thanks!
The third, fourth, and fifth picture in post 30 of the attached thread. Again, thanks a million.
https://ls1tech.com/forums/drag-raci...-t-hook-2.html
