Sponsored by: CARiD
steering rack
Old Nov 9, 2017 | 09:51 AM
1999Trans am's Avatar
Default steering rack
Can any one tell me if a steering rack from a 2002 camaro ss will fit in my 1998 Trans am will i need the steering linkage from the camaro to make it work
Thanks any help would be great
Old Nov 11, 2017 | 05:58 PM
LS6427's Avatar
Looks like they are all the same part numbers on rockauto.com
Old Nov 17, 2017 | 10:10 AM
Need4Camaro's Avatar
Actually becareful. The LS1 F-Body's have about 3 different steering racks ... The only way to truly tell which one you have is to remove the old one and compare it to a physical one.
Old Nov 18, 2017 | 03:07 PM
LS6427's Avatar
Yea...true......or call any dealership and give them his actual VIN....then ask them what the part number is.....
Old Nov 19, 2017 | 08:22 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
From the Camaro parts layout catalog,a 2002 Z28(SS) shows a GM # 2606311(basic core) for FE2,FE4,FE7 suspensions.
From the Firebird parts layout catalog,a 1998 TA shows a GM # 2606311(basic core) for FE2,FE4,FE7 suspensions.
Old Dec 26, 2017 | 10:27 PM
qweedqwag's Avatar
I ordered the GM one from rockauto, worked like a champ.
Old Dec 31, 2017 | 02:05 PM
z28pat's Avatar
Which one did you order from rock auto and how does the car drive now ? Did it help with the loosens in steering?
Thank you
Old Dec 31, 2017 | 02:14 PM
qweedqwag's Avatar
Dis one ACDELCO 36R0391
http://www.rockauto.com/en/moreinfo....sn=594&jsn=594
Mine was leaking, it won't help if you have bad ball joints, tie road ends, or anything connected to the rack or front wheels that is wore out.
