Driver Windows Wheel Guide
While I was replacing my Power Windows motor this weekend, I noticed that the rear guide wheels is pretty messed up. if you look close there is also some rust around it.
Does anyone know If this guide wheel can be ordered? If so what's the Part# and from where.
I have attached 2 photos to show the guide wheel in question. Let me know if you need more.
Basically 2 options
(BEST)
Get someone to weld the piece flat as possible
(second)
Replace the piece with a carriage bolt in place of the wheel and washers/nuts..
That piece is supposed to be solid. The tip of it connects to a wheel and that piece is usually not damaged. The damaged piece is the window "frame" that does not come with the regulator, or window, when ordered.
I am going to complete the repair with a bolt tomorrow
