Ignition lock cylinder, replacing it and how does it work?
So, I've included some cool pics and this is actually pretty easy to do. Between removal, rekeying, and reinstallation, this is a 30 minute job on my vehicle. Tweezers are highly recommended but otherwise, no special tools are needed.
My question, is what is inside the cylinder that works with the ignition switch to make things go and what is failing when the problems start? I see some copper that looks like it might make some sort of electrical connection when turned but otherwise, this thing doesn't have anything obvious to tell me what it's doing
Old one, nothing removed
Moving the old pins into the new one
Pin and springs moved, just need to install the cover
The cylinder turns a cam, which engages a system of linkages, which actuate the actual "ignition switch", which is mounted further down the column. If your swap improved anything it would be because you fixed some sort of mechanical problem in the system.
You can check out this guide and search for "switch". Any search that comes up for the ignition switch will show you the parts in this system. http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
EDIT: thank you for your reply!
In the F-Bodies, with the older style steering column, (your '96 actually has a "newer" column design) all ignition and accessory functions are controlled by linkages connected to remote switches.
The connection you have circled isn't the ignition switch, I believe that's part of the Passlock system. It was an option on trucks, not all of them had it.
