Sponsored by: CARiD
please help me identify this connector
Old Mar 10, 2018 | 09:18 PM
Floorman279's Avatar
Default please help me identify this connector
remove all the emissions awhile ago. decided its time to cut connectors that are leftover and heat shrink the ends and tuck inside the plastic harness protectors. i can't identify this loose one i have on the drivers side. i found a thread with all them labeled, however this connector wasn't there. i have a 2000 camaro ls1 m6. in the pic, there is a white connector just to the left of the knock sensors in this pic. its located in-between 2 injector clips.
Old Mar 10, 2018 | 10:34 PM
LLLosingit's Avatar
Coil harness plug? There are more than one not labeled that I see, can you circle it and repost?
Old Mar 10, 2018 | 11:58 PM
ss.slp.ls1's Avatar
Weird, my '99 harness doesn't appear to have that connector.
Old Mar 11, 2018 | 08:37 AM
i tried im on a stupid mac and can't figure out how to do that. its the white connector 2 connectors down from the coil
Old Mar 11, 2018 | 08:46 AM
i know some seem to have it some don't
Old Mar 19, 2018 | 08:47 AM
Tayj6's Avatar
If you are talking about the white plug that is between the injectors on both banks (2 of them) then they go to the foul harnesses for each bank.
Old Mar 19, 2018 | 12:03 PM
ss.slp.ls1's Avatar
The white connector he is referring to is only on one side, the driver side.
Old Mar 19, 2018 | 01:50 PM
Tayj6's Avatar
My mistake. I didn’t see that one... and I meant coil not foul.
Wouldn’t that be the vacuum solenoid the for AIR injection system.
similar to the red and blue plug that is between the other 2 injectors on the same side that is for evap solenoid.
Old Mar 19, 2018 | 02:00 PM
Tayj6's Avatar
There is a good picture of it in this thread...
https://ls1tech.com/forums/conversio...entifying.html
Old Mar 19, 2018 | 04:37 PM
ss.slp.ls1's Avatar
Okay, I think I get it now. It looks like the '00 and '99 have different smog emissions systems. My '99 harness has an EGR plug on the passenger side near the AC clutch connector that I don't see as present on the posted picture of the '00 harness. My '99 engine doesn't have the white vacuum solenoid as pictured, only the read air pump solenoid is present.
